Friends!
Today we connected the Candy CDI P50-07 dishwasher, but we couldn’t start it. On the panel, when you press the on/off button, all the indicators first light up, then only the rinse aid and salt indicators go out and light up, and the number 22 appears on the display. The machine does not start. True, they didn’t add salt (they didn’t even know that it was needed), but was it really because of this that the machine didn’t start? At the same time, the machine does not respond to the program selection button, only the on/off button works. Please tell me what we are doing wrong... is the problem in the salt or could it be something else?
I can’t perform the first launch of Candy cdi p50-07 ⇐ Candy
Автор темыA partisan
- My dishwasher: Candy cdi 9p50-07
galina
Tell us how you fixed the problem?? I have the same problem with my dishwasher ((
Anton
Re: I can’t run Candy cdi p50-07 for the first time
I have similar problem.
Tell me how you solved it?
Good afternoon.Partisan: Friends!
Today we connected the Candy CDI P50-07 dishwasher, but we couldn’t start it. On the panel, when you press the on/off button, all the indicators first light up, then only the rinse aid and salt indicators go out and light up, and the number 22 appears on the display. The machine does not start. True, they didn’t add salt (they didn’t even know that it was needed), but was it really because of this that the machine didn’t start? At the same time, the machine does not respond to the program selection button, only the on/off button works. Please tell me what we are doing wrong...is the problem in the salt or could it be something else?
You just need to open the door and select the program in this position. I had the same thing, and then I realized. P.S. I still have it without furniture, so the display is visible even when closed.
- 38400 Views
Last post by Olga
