Error E1 Candy CDI P96-07Candy
Dishwashers Candy
Xalemax
My dishwasher: Candy CDI P96-07
Post by Xalemax »
Good afternoon, dears! PMM Candy CDI P96-07 takes in water and then drains. Do this three times. Then error E1 pops up (there are problems with water intake). In fact, it collects water and the pressure changes on the pressure switch. The tube through which pressure is supplied to the pressure switch is dry, clean and not pinched. If you blow into the pressure switch, the changeover contact is activated. Using a pressure gauge from a tonometer, I found out that there was almost not enough pressure to activate the pressure switch in normal mode. Judging by the videos on the Internet, adjusting the pressure switch manually is like throwing it away. Replacing the pressure switch SP-PS01 140-120 is quite difficult; they are not available in Ukraine.
And most importantly, when I tried to launch the PMM program, simulating the operation of the pressure switch using a changeover contact, controlling the real pressure, it did not work. When the contact closes, the PMM drains the water. Please tell me what could be the problem.
 Re: Error E1 Candy CDI P96-07
Look at the sensor (impeller + reed switch) on the water dispenser
  • PMM Candy Ced 112-07 error when turned on
    by Skydiver_58 » » in Candy
    Last post by Skydiver_58
  • Candy CDI 9P45 started to show error E03
    by andrey.portugal » » in Candy
    Last post by andrey.portugal
  • Candy PMM
    by Olga » » in Candy
    Last post by Olga
  • Candy
    by Constantine » » in Candy
    Last post by Constantine
  • Candy CSF 4575 E
    by Rostov » » in Candy
    Last post by Rostov
