Bosch SMV40D00RU stops during washingBosch
alexandr.selifanov
Новичок
Post by alexandr.selifanov »
Hello everyone!
The SMV40D00RU PMM starts, starts washing and suddenly (usually when splashed by the rocker arms) stops, the indicators are on as if the door was opened for additional loading. A light touch like closing the door more tightly and starts washing further and so on many times per cycle. If you don’t "help", it will do the job, but in 5-7 hours. If you prop the door with a handle, the problem disappears.
I thought about the lock, the spring securing the door had weakened, but replacing it with a new lock did not solve the problem..
Where to dig next? Sealant?
Boil
 Re: Bosch SMV40D00RU stops during washing
Post by Boil »
Is the door itself warped?
alexandr.selifanov
Новичок
Boil, but I guess not, I’m not a master, of course. But I don’t see any problems, it closes/opens smoothly, effortlessly, does not creak or play.
Boil
Post by Boil »
Did you remove the façade?
alexandr.selifanov
Новичок
There is no facade at all yet))
Boil
Post by Boil »
It’s just that there was already a case when the facade was to blame for exactly this problem, although more often such a malfunction appears when the filter, drain or sprinklers are clogged with dirt, but if you are okay with this, then look maybe which basket does not completely fit into place after loading the dishes and it rests against the door, look at the seal, maybe it’s coming off somewhere, in the area of ​​the lock, for example, or it’s not holding at all, I would also think about the lock first
alexandr.selifanov
Новичок
In general, I figured it out during the holidays!!! I came across a video of one good master (can I leave links here?) with a VERY similar problem. The door hinge brackets are to blame. I think someone once did not notice the open door of the PMM and stepped on it. These hinges were deformed and the door opened at an angle greater than 90. Accordingly, it did not close tightly. He took them off and straightened them with a hammer, checking the squareness with a square. After about 4-5 washes, the problem no longer appeared, ugh 3 times))
By the way, Bosch has an excellent mode for preparing the PMM for transportation/wintering, described in the instructions. I repeated the necessary manipulations and did nothing else - did not disassemble, did not drain the remaining water in the side tanks, etc. The frosts were more than 30 and the PMM survived them without any problems. Good luck to all!
adm2
Администратор
Post by adm2 »
aleksandr.selifanov: 17 Jan 2022, 10:56 I came across a video of one good master (can I leave links here?)
If the video is on YouTube, then yes, you can. :)
alexandr.selifanov
Новичок
adm2: 17 Jan 2022, 14:38 If a YouTube video, then yes, it is possible. :)
Then vote.
. A moment when the disassembly of the doors began - at 18:20
  • Bosch SMV40D00RU/34 throws the pill away
    by Kahhhhx » » in Bosch
    Last post by Einstein
  • Hansa ZWM 627 IH stops washing and switches to different modes
    by mahanka » » in Hansa
    Last post by mahanka
  • Flavia 45 Ivela Light stops washing after 30 minutes with an error
    by TonyVZ » » in Flavia
    Last post by Goga
  • The PM stops the washing cycle, there is a little foam inside and powder that has not been washed out of the filling tray. Zanussi ZDV91506FA
    by mrPu » » in Other manufacturers
    Last post by mrPu
  • BOSCH SPS40E 45 cm stops at rinsing
    by Irina » » in Bosch
