Hotpoint ariston LSF 7237 help with diagnostics, 3h and 9h flashingHotpoint-Ariston
Andrey V.
My dishwasher: hotpint ariston LSF 7237
Post by Andrey V. »
During the washing process, the 3h and 9h indicators start flashing. help identify the error.
Artem
 Re: Hotpoint ariston LSF 7237 help with diagnostics, 3h and 9h are blinking
Post by Artem »
If the wash and end of wash indicators are on in the dishwasher with a flashing power indicator, this means the dishwasher tray is flooded, the PMM does not start the mode to avoid flooding, you need to dry the tray in the PMM and check whether the drain filter or drain hose is clogged, if after the next wash the error repeats then you need to check the drain pump for serviceability
Andrey V.
Post by Andrey V. »
Only 2 indicators 3h and 9h are flashing. and the machine is trying to drain the water
Quartz Grill
Post by Quartz Grill »
The 3h indicator flashes and the pump is running
  • Hotpoint Ariston LSF 7237
    by Fatal » » in Hotpoint-Ariston
    Last post by Fatal
  • Hotpoint Ariston LSF 7237 Wash and cycle end error.
    by Alexei » » in Hotpoint-Ariston
    Last post by Kreutzkopf
    Last post by Port
  • Hotpoint Ariston lst 11477
    by Alexey78 » » in Hotpoint-Ariston
    Last post by Alena
  • Hotpoint ariston adls 7
    Last post by Louisa
