The flow distribution mechanism is leakingBosch
oleg185@list.ru
Post by oleg185@list.ru »
It drips from the white plastic case to which the motor of the flow distribution mechanism is attached, sometimes it drips onto the motor itself. During a wash cycle, about 50-100 grams leak. It looks like the reason is the seal at the wheel axle with holes for flow distribution? Please tell me how to solve the problem: should I order the entire mechanism assembled or are there other ways to deal with this disease?
Artem
 Re: The flow distribution mechanism is leaking
Post by Artem »
Well, if you understand the mechanisms of PMM operation and are sure that the leak is in this particular part, then first inspect the O-rings, they are probably there because they are in contact with water, but you will always have time to spend money on the entire assembled mechanism! If you are not sure about the cause of the leak, then contact the service!
  • Water does not flow into the PMM
    by Vitaly » » in Electrolux
    Last post by Elena B
  • Colleagues, please tell me. Water does not flow into the PMM
    by Kirill » » in Siemens
    Last post by Kirill
  • Water does not flow into the dishwasher.
    by AndreyKursk » » in Indesit
    Last post by AndreyKursk
  • Flow regulator, actualizer. Bosch
    by Farsan » » in Bosch
    Last post by Farsan
  • Water does not flow into the heat exchanger
    by fight back321 » » in Bosch
    Last post by fight back321
