Operating mode only under pressureElectrolux
create
My dishwasher: Zanussi ZDS 200
Post by create »
Hi all. Machine Zanussi ZDS-200, more than 10 years old.
On the third day the exhaust pump began to malfunction, I, on the advice of the specialists, did not wait, but immediately bought a new one and replaced it. When I changed it, I put the machine on its back.
After this, the following syndrome appeared: it takes in water, but when it’s supposed to turn on the circulation and start actually washing, it freezes. At first, this happened only before the last phase - i.e. by the end of the first hour of the program. It helped to briefly press Start, and the machine, waking up, began to turn.
Today this turned out to be not enough. I press Start and it will spin a couple of times and freeze again. Restarting the program after that did not help - pressing the button was enough either for a second of work, or it did not react at all.
This was the case in the morning. I then started the program from scratch again to drain the accumulated water, and turned it off. Now, four hours later, I tried to restart the program again - it started working normally.
What was it and how to treat it? It seems that during operation some sensor somewhere gets clogged; and after four hours of inactivity it dried out.
Thank you
  • Dishwasher operating hours
    by marathi » » in General questions about dishwashers
  • Questions about connecting and operating the dishwasher
    Last post by Lydia
  • Whistle/squeak when operating Hotpoint Ariston LTF11M116
    by aloha » » in Hotpoint-Ariston
    Last post by aloha
  • Weak pressure
    by silence » » in Siemens
    Last post by silence
  • No water pressure BOSH SRV 55
    by Novel » » in Bosch
    Last post by Novel
