Dishwasher operating hoursGeneral questions about dishwashers
marathi
Post by marathi »
Tell me how long the dishwasher should run in normal mode. I have 3.5 hours - is this normal?
 Re: Dishwasher operating hours
Marat, is it always like this, from the very beginning of operation?
And is the machine new? If yes, then now they really are making dishwashers with extended cycles. This is due to environmental requirements and energy savings, primarily at the drying stage.
Previously, no attention was paid to this, and cycles lasted an hour and a half.
marathi
Post by marathi »
The machine is new Bosch, not very fancy. I didn’t notice it from the very beginning because they set the timer at night.
Marat:The car is new
Then it’s probably ECO - fresh trends in terms of environmental friendliness. *x)
May be. Why did I ask the question? After moving to a new apartment, my washing machine started taking twice as long to wash. It turned out that the drain should have been placed higher. I had to buy a pipe for the sewer and lift up the drain. Everything fell into place. Maybe there is some trick here too?
We have an Electrolux car and also had the same issue. When you start the program, it says that it will wash for 2.5 hours, but it washes for more than three. We called Electrolux today and they told us that this is acceptable because... Depends on a number of reasons: water temperature (it is colder in winter), voltage drop to 210 volts or less also affects operating time, water pressure. By default, it shows the average time.
  • Questions about connecting and operating the dishwasher
    Last post by Lydia
  • Operating mode only under pressure
    by create » » in Electrolux
    Last post by create
  • Whistle/squeak when operating Hotpoint Ariston LTF11M116
    by aloha » » in Hotpoint-Ariston
    Last post by aloha
  • How does a dishwasher work? 3D animation of the operation of the internal elements of a dishwasher.
    Last post by Anastasia
  • Starting the dishwasher for the first time, useful tips on using and caring for the dishwasher
