Circulation system. 3 S-shaped nozzles.
Filtration system. Easy to disassemble, with a maximum area of filter elements, prevents clogging. Motor with speed control function. Saves water and energy consumption for higher productivity and protection of the environment.
Discharge device. Designed for 2-zone washing, switches the water flow and optimizes the efficiency of its consumption. Electronic salt adjustment "Smart" dispenser sets the optimal water hardness. Electronic Aqua-stop Automatically turns off the water supply if a leak is detected. n Sent later 22 minutes 38 seconds:
3D animation of the operation of the internal elements of a dishwasher Flavia Kaskata
n
