By itself it reduces washing time ⇐ Bosch
Автор темыLocal
Hello. The following problem arose; The Bosch SPS69T02 machine began to inexplicably reduce the washing time. That is, a process is underway, the remaining time on the clock, for example, is 1:45, then suddenly it becomes 1:20. It seems that it is missing some element of the wash, but it is not clear which one. The rinse aid is filled, there is salt, water flows in and out normally. However, the dishes became less well washed. Any ideas what it could be? Or call a technician right away?
Re: It itself reduces washing time
Good afternoon I have the same problem. Tell me what happened to your machine, how did you resolve this issue?
Yuri
- Интересующийся
The suggested washing time is always in the form of a forecast. The time during washing can be adjusted and either increased or decreased. It depends on the sensor readings. How often do you clean filters? Manufacturers recommend washing filters after each wash.
Good afternoon We bought a Hotpoint dishwasher recently, now I turn on the program, it reduces the time very quickly, you open it, and it feels like you just washed it with cold water without drying it and the tablet is in place.
- 8 Replies
- 11483 Views
Last post by He remembers
