Kuppersberg heating timeOther manufacturers
Samburic
Post by Samburic »
Hello.
Dishwasher KUPPERSBERG GLA 689.
The heating time skips.
Example: program 2 (drain, wash 35°, drain, hot rinse, drain)
From 30 to 29 drain
From 29 to 28 water supply
From 28 heating (Ten) and washing are turned on
Heats @ minute
After a minute on the display instead of 27 minutes, immediately 22 minutes and Ten turns off.
Also the hottest rinse. From 15 to 14, fill the water
From the 14th minute, the rinse and Heat (heating) are turned on
After a minute, the display immediately shows 04 minutes instead of 13 minutes and at the same time the Heat relay clicks off (heating stops).
I checked the temperature sensor. (50 kOhm at room temperature. Heat, resistance decreases)
Ten. Resistance 30 Ohm there is no leakage to the case.
Power supply +12 and +5 is stable.
Narev skips in the operating algorithm. What’s the ambush?
 Re: Kuppersberg, heating time
When the shade is turned off, the same thing happens.
The sink completes the cycle, but the water heating skips.
  • Kuppersberg gla 689
    by Andrei99 » » in Other manufacturers
    Last post by Andrei99
  • Tell me about Kuppersberg GS 4505
    by Samseu » » in Other manufacturers
    Last post by Samseu
  • Kuppersberg GS 4502 when first turned on and error E 2, now rebooted E5
    by Leo » » in Other manufacturers
  • Sometimes but not every time when washing, error 20
    by Andrey air » » in Electrolux
  • Doesn't start the first time
    by aleksandra » » in Bosch
    Last post by Matrix
