The machine itself reduces washing timeHotpoint-Ariston
zippo
Post by zippo »
Hello. The following problem has arisen: the Hotpoint-Ariston LFF 8S112 machine inexplicably reduces the washing time. That is, a process is underway, the remaining time on the clock, for example, is 1:45, then suddenly it becomes 1:20. It seems that it is missing some element of the wash, but it is not clear which one. There is a tablet, there is salt, water comes in and goes out normally. However, the dishes are not always washed. Any ideas what it could be? Or call a technician right away?
 Re: The machine itself reduces washing time
Maybe your machine is connected to hot water, and therefore the heating stage is skipped?
muhammed
Post by muhammed »
no it is connected to cold water
Casing
Post by Casing »
Hello. The following problem has arisen: the Hotpoint-Ariston LFF 8S112 machine inexplicably reduces the washing time. That is, a process is underway, the remaining time on the clock, for example, is 1:45, then suddenly it becomes 1:20. It seems that it is missing some element of the wash, but it is not clear which one. Tablet there is, there is salt, water flows in and out normally. However, the dishes are not always washed. Any ideas what it could be? Or call a technician right away?
© Source: The machine itself reduces the washing time
  • By itself it reduces washing time
    by Local » » in Bosch
    Last post by Airfreshfilter
  • Sometimes but not every time when washing, error 20
    by Andrey air » » in Electrolux
  • mash glass washing machine
    by diamond » » in Other manufacturers
    Last post by diamond
  • Doesn't start the first time
    by aleksandra » » in Bosch
    Last post by Matrix
  • Help, soapy water all the time
    by Screw17 » » in General questions about dishwashers
    Last post by He remembers
