PMM ariston lstf 7b019 turns on, but does not startHotpoint-Ariston
Tanya
Post by Tanya »
Hello! Help! My Ariston lstf 7b019 dishwasher stopped starting one day; it only did this if I slammed the door hard. But at the same time it turned on and the indicator on the display was on. And then it stopped running altogether. I found on the Internet that the problem could be with the lock (locking block), found it on the Internet (I saw that mine was on the compatibility list), and ordered it. I unscrewed the door, changed the lock, tightened it, but everything was the same.
What to do, maybe someone had a similar situation!?
  • Ariston LL 40 Turns on but does not start the wash cycle
    by zakkrnd » » in Hotpoint-Ariston
    Last post by zakkrnd
  • Hotpoint-Ariston LSFB 7B019 problem with rinse aid.
    by SergeyP » » in Hotpoint-Ariston
    Last post by SergeyP
  • First start. Doesn't heat the water and turns off after 20 minutes :(
    by Lisa » » in Bosch
    Last post by Chipmunks
  • LSI 48A (Ariston), pump does not start
    by walex » » in Hotpoint-Ariston
  • Repair of PMM ARISTON LI41, when the circulation pump is turned on, it turns off. The pump works directly without problems.
    by tdcapital@mail.ru » » in Hotpoint-Ariston
    Last post by tdcapital@mail.ru
