Hotpoint-Ariston LST 53977. Indicators stopped lightingHotpoint-Ariston
constrain you
Post by constrain you »
Hello.
Hotpoint-Ariston LST 53977. The indicators have stopped lighting.
If the machine does not turn on for a long time, then when you turn on the power button for a few seconds the indicators and buzzer work (sometimes you even have time to select the operating mode). Then they go out. The buzzer also beeps barely audibly. In complete silence you turn it on, select a mode and it works. The conclusion is that the voltage on the indicators is leaking somewhere. I couldn’t find the diagram anywhere. Today we replaced two electrolytes on the power supply with no results.
If anyone has experience, please share.
Air Shower
 Re: Hotpoint-Ariston LST 53977. Indicators stopped lighting
Post by Air Shower »
Ariston has the same problem: the power indicator lights up and makes one beep; the program indicators light up for a fraction of a second and nothing else happens, have you solved the problem?
  • Hotpoint Ariston lst 11477
    by Alexey78 » » in Hotpoint-Ariston
    Last post by Alena
  • Hotpoint Ariston LTF 11S112
    by yokull » » in Hotpoint-Ariston
    Last post by Maxim T.
  • Hotpoint ariston adls 7
    Last post by Louisa
    Last post by Port
  • Hotpoint Ariston LSF 7237
    by Fatal » » in Hotpoint-Ariston
    Last post by Fatal
