The dishes are salty after washing and the salt runs out quicklyBeko
Vyacheslav
Post by Vyacheslav »
After washing, the dishes are all salty and the salt icon is lit. I added 1.5 kg of salt before washing. Please tell me what could be the matter.
Partizan
 Re: Dishes are salty after washing and quickly run out of salt
Post by Partizan »
Vyacheslav: 20 Feb 2019, 19:52 What could be the matter
Is the dishwasher old? If so, then most likely there is corrosion, a hole somewhere inside. Water from the salt compartment quietly merges with the general flow.
The machine is 4 years old. If you turn it over, salt streams out from under the ion exchanger cover, I tried another cover, same thing, I blame the tank. Can you tell me how to unscrew the plastic nut to remove the tank and install a new one.
Post by Fulcrum »
Partisan: 20 Feb 2019, 23:05
Is the dishwasher old? If so, then most likely there is corrosion, a hole somewhere inside. The water from the salt compartment quietly merges with the general flow.
Sorry.... What can rust in the ion exchanger or in the salt tank?! *x)
Partizan
Post by Partizan »
Fulcrum: 22 Feb 2019, 21:10 And what can rust in the ion exchanger or in the salt tank?!
It may not rust, but there is probably a hole somewhere.
Post by Fulcrum »
Partisan: 23 Feb 2019, 11:06
Fulcrum: 22 Feb 2019, 21:10 What can rust in an ion exchanger or in a salt tank?!
It may not rust, but there’s probably a hole somewhere .
Well, figuratively speaking, then yes
Zenek
Post by Zenek »
Take a cloth and screw the cap on the neck of the salt tank
  • PMM Beko DIS 25010 - leaves a white coating, runs out of salt quickly
    by Elena K » » in Beko
    Last post by Cargo
  • Salty dishes after washing
    by Sergev.an.cap » » in Beko
    Last post by Aggregate
  • Salty dishes
    by Svetlana » » in Beko
    Last post by Svetlana
  • Plaque on dishes after washing
    by Stealth » » in Dishwasher chemicals
  • After washing the dishes have a white coating
    by Dmitry Katanaenkov » » in Bosch
    Last post by Dmitry Katanaenkov
