Indesit idl40 does not drain waterIndesit
Beach
My dishwasher: Indesit idl40
Post by Beach »
Hi all. Problem with dishwasher indesit idl40. After washing, water remains in the machine. No indicators are blinking. The filter is clean. At the same time, in mode "4" - rinsing, the water is completely drained. Where to dig?
 Re: Indesit idl40 does not drain water
There is no need to dig :) It’s just that, as far as you can see... a filter is just one name, a lot can pass through it and get directly into the system, and then cause trouble, causing the filler and drainage system to work incorrectly systems. good masters at SC Akata will help you figure this out...
Multielectrode
Post by Multielectrode »
Damn smart advice
What is "akata"? Where is it? What does dirt have to do with the pipes?
Post by Fulcrum »
:-D
Energy class
Post by Energy class »
Multielectrode: 16 May 2023, 11:50 Really smart advice
What is "akata"? Where is it? What does the dirt in the pipes have to do with it?
This was written by the master of the Akata SC :ROFL:
  • Indesit DSG 5737 - noise and water does not flow to the lower rocker arm.
    by Ingwarr » » in Indesit
    Last post by Ingwarr
    by Olga Olga » » in Indesit
    Last post by Olga Olga
  • Water does not drain
    by TatyanaOren » » in Bosch
    Last post by TatyanaOren
  • Beko does not drain water
    by Lord Curzon » » in Beko
    Last post by Lord Curzon
  • Dishwasher did not drain water
    by Slavic » » in Bosch
    Last post by Screams
