Forgot to close the salt holeGeneral questions about dishwashers
qwerta
Post by qwerta »
Good afternoon!
Today the light on the lack of salt came on, I went to add it and discovered that the hole for salt was not closed!!! Apparently I forgot to close it after adding salt last time. And the lid still lay on the bottom. And after all, I washed the dishes like that for quite a long time. Moreover, this did not affect the quality of the wash in any way.
I started pouring salt into the hole, and from there rotten, stinking water with food residues began to come out (((I poured as much salt as I had, but it didn’t go all the way to the top, so I decided to add more fresh water there to displace the rotten water. Terrible smell filled the entire kitchen!
Who has encountered this situation? Is it possible to wash this compartment somehow? For example, by pumping out all the water from there and pouring fresh water, as before the first wash?
Albert
 Re: Forgot to close the salt hole
Post by Albert »
qwerta:by pumping out all the water from there and pouring fresh water, as before the first wash?
I think this is the best option. Try to scoop out this water completely, with an enema, a syringe or something else.
I don’t think it ruined the machine, but it’s certainly unpleasant.
How did the matter end? They didn’t close the compartment either, the machine broke down. Because of this?
What exactly is broken for you?
Puppeteer
Post by Puppeteer »
I also forgot to close it. I washed it a couple of times, maybe 3. And then only because the dishes were covered with a white coating I saw the lid open. What to do? Now all the dishes have a white coating on them.
  • There is a hole in the dishwasher
    by Tatyana77 » » in Other manufacturers
    Last post by Olga.leonidova
  • Bosch smv65m30ru, dripping from the hole in the front
    by Leonid » » in Bosch
    Last post by Puppeteer
  • The door won't close
    by LuterDM » » in Siemens
    Last post by LuterDM
  • Brant's door won't close. What should I do?
    by Guest » » in Other manufacturers
  • Dishwasher door won't close
    by arlei » » in Bosch
    Last post by Super freezing
