Dishwasher door won't close ⇐ Bosch
Автор темыarlei
Help me please! I’ve been jumping around the Bosch dishwasher all evening. The latch on the lock has popped out and the door will not close. This happened a couple of years ago, somehow I was able to close it. It doesn’t work right now
Roman 1
Re: Dishwasher door won't close
In such cases, I use a screwdriver or the back of a spoon to snap it back. You need to insert it behind this latch - as if perpendicular to the floor surface, and press it towards yourself.
Автор темыarlei
Roman1, grateful - I can’t describe how! A second and that’s it, but yesterday I surfed the entire Internet and sat with a
screwdriver until 2 am. This is what it means - men’s help!
Roman 1
arlei, glad it helped.
I once crawled all over the Internet and found the answer only in the comments on YouTube.
alex
And if the latch is in the normal position, but the door still does not close, what should you do?
Roman, thanks for the advice. Helped a lot. I was already getting ready to disassemble the door.
Veko machine - latch in the door. Do you need to disassemble the door? Doesn’t click when pressed
K Artem
Guest, but the method described in the first message does not help? Or does Veko have a different device than Bosch dishwashers?
Holy
Roman, thank you! I stabbed myself with a screwdriver.
And with a spoon it immediately turned out perpendicular
Matrix
What should you do if the lock accidentally clicks in the same way, but the lock is on the door of a Bosch machine?
Matrix
I just foolishly stuck the end of a spoon into the lock, and it worked (closed)
Retraction
Matrix, it’s good that it’s the end of a spoon and not something else
spunyaev@yandex.ru
Good afternoon, my name is Sergey. The lock tongue keeps popping out, so I use a spoon to put it back in place. Maybe there is some way to fix this once and for all? Thank you in advance
