Guys, according to my wife, the frying pan on the top shelf did not fit the dimensions and when loading it hit some kind of tongue in the upper part of the PMM where the lock is. There was a click. Now the PMM door does not close because... The lock tongue has come out and is preventing the door from closing.
It seems to me that this is basically some kind of nonsense, but I can’t understand how to fix it.
Tell me what to do?
If you need a photo or anything else, I can hang it up.
Sent after 17 minutes 28 seconds:
Apparently the child lock was activated.
But the manual doesn’t make anything clear.
Guys, according to my wife, the frying pan on the top shelf did not fit the dimensions and when loading it hit some kind of tongue in the upper part of the PMM where the lock is. There was a click. Now the PMM door does not close because... The lock tongue has come out and is preventing the door from closing. It seems to me that this is basically some kind of nonsense, but I can’t understand how to fix it. Tell me what to do? If you need a photo or anything else, I can hang it up.
[size=85][color=green]Sent after 17 minutes 28 seconds:[/color][/size] Apparently the child lock was activated. But the manual doesn’t make anything clear.
Help me please! I’ve been jumping around the Bosch dishwasher all evening. The latch on the lock has popped out and the door will not close. This happened a couple of years ago, somehow I was able to close it. It doesn’t work right now :sorry:
Can anyone tell me what to do about this or how to adjust it? After 6 years of operation, the door began to leak in the upper part (from the control panel side). In fact, when I pulled out the dishwasher, I discovered that the door seemed to be warped and moisture began to seep out in the upper right part of the door due to a loose fit during operation.
Door won’t close dishwasher, the rinse aid indicator is constantly on, although rinse aid has been added. The door opens immediately and the dishwasher does not start
Good afternoon!
Today the light on the lack of salt came on, I went to add it and discovered that the hole for salt was not closed!!! Apparently I forgot to close it after adding salt last time. And the lid still lay on the bottom. And after all, I washed the dishes like that for quite a long time. Moreover, this did not affect the quality of the wash in any way.
I started pouring salt into the...
I also forgot to close it. I washed it a couple of times, maybe 3. And then only because the dishes were covered with a white coating I saw the lid open. What to do? Now all the dishes have a white coating on them.
