Good afternoon Please help. Suddenly, unexpectedly, at the moment of pressing the OK button, the indication of operating modes on the display panel disappeared. The inscriptions have disappeared - there is only a red screen on which these same inscriptions are not present. The machine nevertheless works, the “beam on the floor” shines and the lighting in the machine works when the door is opened and the set washing mode works completely correctly. But the mode is, of course, chosen blindly. I tried disconnecting the machine from the network for several hours - it did not help.
How to fix this shortcoming?
Flavia bi 45 kamaya - failed dashboard indication ⇐ Flavia
Kasparik
Re: Flavia bi 45 kamaya - failed dashboard indication
Open the door and inspect the indication board. Not power, but exactly where the display is. Often, due to work and steam, oxides form on the board and the soldering of the elements is destroyed.
Bessharova
Same story, fee is ok. I raised the screen and everything was fine there.
Cargo
- 10 Replies
- 45844 Views
Last post by desoder
- 4443 Views
Last post by Romario 21
