Good afternoon Please tell me, I took the PMM Ariston CIS LI 700 DUO from a friend. The friend said that the drain pump in it did not work and that he had already changed it before. Well, okay, I opened the PMM to see what kind of pump it was and saw the following. Not only is the barrel for regeneration salt broken, which is a minor thing in principle. I discovered that there was a sensor hanging loose and not attached anywhere. Can you tell me what kind of sensor this is and where it should be located. The sensor and where it was located in the photo. Thank you very much in advance!
http://s2.micp .ru/Rb8e9.png
n
http://s1.micp .ru/rmc29.png
Ariston cis li 700 duo ⇐ Hotpoint-Ariston
- 2 Replies
- 21087 Views
Last post by Pavel82
