water flows continuouslyGeneral questions about dishwashers
Andrey Marenkov
Post by Andrey Marenkov »
Hello!
Last summer, a CANDY CDP 4609 dishwasher was purchased and placed on a summer veranda in the village. It worked all summer without problems (turned on no more than 10 times). For the winter she was sent to a heated house, which is located 5 meters from the veranda. After the weather warmed up (last weekend), the machine was returned to the veranda and connected. After turning on the power and opening the water tap, water began to flow into the machine without stopping until it flowed onto the floor. The "Water overflow" icon blinked on the display. The tap was turned off and the floor was wiped. The machine was not leveled (a little at all). They were set strictly horizontally. We tried running the water a couple more times. All the same. At the same time, the pump did not try to pump out water from the machine. Question: what could have happened over the winter? Maybe something was damaged during transfer? The two carried it very carefully, without touching anything. We want to take it apart and have a visual look. What should you pay attention to? Thank you
 Re: water constantly pouring
Good afternoon There should be a float in the PMM pan, which is responsible for ensuring that the dishwasher drains water; if the PMM has not been used for a long time, then for many reasons it could have dried out, you need to check this float
Andrey Marenkov
Thank you! I haven’t reached the float yet. I removed the back wall and turned on the water. It turned out that the very first connection after the water supply hose had broken. The valve (or whatever it is) was half torn out. I glued it, I’ll try it next weekend.
worry
Post by worry »
similar situation, PMM Midea was purchased new and stood for 2 years
connected - water pours non-stop. Hmm, I thought and added a kilogram of salt, it still poured.
I removed the side cover - visually everything was ok, I looked at the sensor on the salt tank above the middle, and the salt below
I added salt to the top and everything was ok
  • Water flows
    by Max666 » » in Electrolux
    Last post by Psy40263
  • Electrolux esf 43020 aquastop is triggered, it flows from two hoses into the pan
    by max » » in Electrolux
    Last post by Flash
  • Continuously warms
    by March » » in Hotpoint-Ariston
    Last post by March
  • Candy 4609X Continuously washes
    by Continuously washes » » in Candy
    Last post by Continuously washes
  • The modes on the panel flash continuously.
    by Alexsei » » in Candy
