FAGOR 1VF-65IT dishwasher does not turn on (salt indicator)Fagor
dmitryxxx
My dishwasher: FAGOR 1VF-65IT
Post by dmitryxxx »
Hello!
I encountered the following problem: the FAGOR 1VF-65IT dishwasher does not turn on.
It was like this: I put the dishes in the dishwasher and before closing the door, I press the mode as usual sink, close the door. I hear that it doesn’t turn on - I open the door again and two indicators are on:
- indicator of lack of salt in the salt tank
- indicator of lack of washer fluid (for glass).
I poured washer fluid into a special compartment and the "no washer fluid" indicator went out. Next, I poured salt into the salt tank (I poured less than half or more like a quarter of the tank), but for some reason the indicator did not go out. If I correctly understand the operating principle of this dishwasher, it will not start until all the reasons are eliminated. Turning off the machine from the electrical network and turning it on again did not help (I thought that it would somehow check again that I had added salt and turn off the signal for the lack of salt in the tank).
The question is the following:
1. In your opinion, what could be the reason why the machine does not turn on (washing does not start)?
2. Maybe because the tank ran out of salt, the salt sensor (or whatever it is correctly called) became covered with something (maybe lime or something else) and now, even after pouring in a little salt, “it seems to him” that there is none?
3. Maybe you need to fill the entire salt tank completely with salt and only then will the “salt sensor” think that the tank is full, after which the indicator will disappear and the machine will start?
Please tell me what to do about this situation.
Regards,
Dmitry
dmitryxxx
 Re: FAGOR 1VF-65IT dishwasher does not turn on (salt indicator)
Post by dmitryxxx »
Hello again!
Today I seem to have solved the problem with salt, I fell asleep to the maximum and the indicator disappeared. However, the machine still does not start: I turn on any of its washing modes, the mode indicator lights up, I close the door, but the washing process does not start.
Please tell me, maybe there is something else I need to do ?
  • The dishwasher FAGOR 1VF-65IT does not start washing
    by dmitryxxx » » in Fagor
  • Beko dsfs1530 indicator blinks and does not turn on
    by We get angry » » in Beko
    Last post by Abyssinian Well
  • The salt indicator does not go out.
    by Sergey.bobrovsky » » in Midea
    Last post by Guest)
  • The salt indicator does not go out in the new Bosch SMV25AX01R
    by alt-x » » in Bosch
    Last post by Exe11111
  • The salt indicator lights up and water pours out when you open the tank.
    by Leon » » in Other manufacturers
    Last post by Leon
