Dishwasher KRONAsteel BDE 4507 EU.
Doesn’t work. Turns on but doesn’t start. Error E1 flashes - no water supply. I took it apart with my father - the solenoid valve of the inlet hose does not work (does not open water from the faucet for the machine).
What we did:
We disassembled it, rang the resistance of the valve (disconnected it from the circuit) - shows an open circuit (doesn’t even react), they took and applied direct voltage from the socket to the disconnected valve in the hope that it would start opening the damper there - it doesn’t react.
We also connected the machine to the circuit and connected a multimeter to the wires that go to this valve from the control system - no voltage is supplied to these wires.
Presumably the coil on the solenoid valve burned out, since it does not show resistance (or unless there is some kind of trick involved) but the voltage is also not supplied to the valve, apparently higher up the circuit from the relay some kind has failed.
What should I do? Is the solenoid valve itself broken? and why is it not receiving voltage from the control system?
KRONAsteel BDE 4507 EU - not working, main valve apparently. ⇐ Chrono
Re: KRONAsteel BDE 4507 EU - not working, apparently the main valve.
what should the valve coil resistance be?
Throw the fuck out of this crap. Buy a Mielee for 150,000 and calm down.
How to tell if the top imploer is working
by Quartz Grill » » in General questions about dishwashers - 1 Replies
- 1980 Views
Last post by Sector
- 29580 Views
Last post by LarSon68
- 12658 Views
Last post by igor
