Bauknecht GCXP 7240 machineOther manufacturers
Tatiana N.
Post by Tatiana N. »
I bought a new PPM (I didn’t have one before, I don’t understand them). I managed to complete about 10-12 cycles. The salt and rinse aid indicators do not light up (although according to the instructions they should be enough for 4-6 cycles). The rinse aid level (according to the instructions) can also be determined by eye using special windows. But nothing is clear and it is not visible how much rinse aid there is in the car. Help me please! Thank you in advance!
 Re: Bauknecht GCXP 7240 machine
Tatyana N.:according to the instructions they should be enough for 4-6 cycles
Something is not enough. Are you sure you read 4-6?
20-30 cycles is normal. And salt consumption also depends on the hardness of tap water. How much salt did you add?
And further. Do you use tablets or powder? If it’s tablets, then there’s also salt in there, so the amount poured into the compartment will be wasted less.
Tatiana N.
I use powder. I filled a pack of salt, 1.5 kg. Water hardness is medium. 4-6 cycles are about the rinse aid, I’m also interested in this point.
Tatyana N.:I filled a pack of salt, 1.5 kg.
This will last a long time!
Tatiana N.:. 4-6 cycles are about rinse aid,
Too little! Some kind of typo. The rinse aid is added even a little less frequently than the salt.
In general, wait until the indicators light up. It’s too early for them to catch fire.
  • Curting machine
    by Guest » » in Other manufacturers
  • what kind of machine should I buy?
    by Elena Bill » » in General questions about dishwashers
    Last post by Kirlaa
  • How to reset a machine
    by to max_k » » in Flavia
    Last post by burn
  • The machine does not turn on
    by ssob_i@bk.ru » » in Bosch
    Last post by Vlad
  • The new machine does not wash
    by Elenaled » » in Hotpoint-Ariston
    Last post by Elenaled
