Water in the pan GORENJE GV 64311Burning
andrey.r
Post by andrey.r »
Hello!
I encountered the following problem.
Water accumulates in the tray in the dishwasher. Immediately after washing there is no water, if you turn off the valve on the water supply, then everything seems to be fine (by the way, that’s what it says in the instructions). But because I usually run the washer at night, then by the morning the tray is full. By the way, I noticed that it even automatically pumps out when there is excess water when it is turned off, so that nothing overflows. But it seems to me that it shouldn’t be like this, what if the electricity is turned off and the pumping doesn’t work on time? Yes, and I don’t always use a dishwasher every day, it’s unknown how such an amount of water will affect the p/m if it sits in the pan for a long time?
I’m thinking maybe a valve just doesn’t hold or there’s excess pressure in the pipeline?
  • The gorenje gv66161 dishwasher squeezes out the rubber in the water supply pipe.
    by enzof » » in Burning
    Last post by enzof
  • Gorenje gv-54311
    by winmd » » in Burning
    Last post by winmd
  • I don’t know what to do gorenje gv64311
  • PMM Gorenje MGV5511 - error E4.
    by Fedor » » in Burning
    Last post by Ozernik
  • Details Gorenje GV51011
    by Yaliya 177 » » in Burning
    Last post by Yaliya 177
