Works loudly, hum smv68ix00eBosch
Rew1s
Post by Rew1s »
Good afternoon, I have encountered a problem. When the dishwasher is operating, a fairly loud hum of operation is heard, low-frequency, similar to the operation of a drill in the next apartment (not very loud, but unpleasant)
The sound comes from the bottom right of the dishwasher.
I did all the basic things that could be done before disassembling the dishwasher. I made sure that nothing was knocking inside, checked the filter, everything was clean. I ran the machine with somat cleaning agent.
It washes perfectly. There are no errors.
Since I bought it secondhand, I don’t know how it worked before. But I’m sure it should be quieter. The machine is 4 years old.
Where is the problem most likely to be? Could this be, for example, due to wear on the pump? and What is the probability that it is the motor itself?
Thank you!
Olga.leonidova
Новичок
 Re: Loud operation, hum smv68ix00e
Post by Olga.leonidova »
This happens when a mechanism malfunctions. If the noise stops after closing the water tap, then the problem lies in a faulty inlet valve.
Rew1s
Post by Rew1s »
For some reason I have a suspicion that this may be a problem with the bushings of the circulation pump, the only question is that this sound occurs throughout the entire washing cycle. Does the circulation pump work throughout the entire wash?
In any case, today or tomorrow they will disassemble the machine and see what’s there
  • How condensation drying works
  • indesit 0507 works but there is a hum
    by Sabina » » in Indesit
    Last post by Sabina
  • How the Beko 6630S dishwasher works
    by Shadows » » in General questions about dishwashers
    Last post by Shadows
  • BOSCH SRV55TO3EU - only the pump works
    by alwol » » in Bosch
    Last post by Want to know everything
  • The programmer either works or doesn't work
    by Svetlana » » in Other manufacturers
    Last post by Svetlana
