Circulation pump PMM BEKO DFS 2520 jamsBeko
Dmitry 2520
Post by Dmitry 2520 »
The PMM draws water and then stops - the circulation pump motor hums and does not pump water. I noticed that the spring-loaded impeller inside the volute is not fully pressed, the latches do not completely come out of the grooves, as a result of which the impeller in the volute jams, the engine cannot spin
  • Repair of PMM ARISTON LI41, when the circulation pump is turned on, it turns off. The pump works directly without problems.
    by tdcapital@mail.ru » » in Hotpoint-Ariston
    Last post by tdcapital@mail.ru
  • Bosch circulation pump
    by Romario 21 » » in Shopping Row
    Last post by Nippers
  • The circulation pump is leaking(?)
    by Sandroe » » in Electrolux
    Last post by Abyssinian Well
  • Search for a circulation pump for PM SMS44GIOOR
    by Pavel V » » in Bosch
    Last post by Handshake
  • Replacing bushings on the circulation pump
    by Alex » » in Other manufacturers
