Replacing bushings on the circulation pumpOther manufacturers
Alex
Post by Alex »
Hello. The pump on the Ariston dishwasher began to jam, replaced the graphite bushings, assembled it, applied 22, it works, screwed the heating element into place, let it go, it works. I stuck my finger through the pipe in the heating element, twisted and spun, applied 220, wedged. 2 days I don’t know what to do
Cheer up
 Re: Replacing bushings on the circulation pump
Post by Cheer up »
Well, I guess I bent the shaft while I was changing the bushings.
Post by Fulcrum »
Alex: 22 Oct 2021, 17:56 Hello. The pump on the Ariston dishwasher began to jam, replaced the graphite bushings, assembled it, applied 22, it works, screwed the heating element into place, let it go, it works. I stuck my finger through the pipe in the heating element, twisted and spun, applied 220, wedged. For 2 days I don’t understand what to do
What kind of Ariston is this, where the pump has bushings instead of bearings, maybe it’s Hotpoint?
  • Replacing the circulation pump with a different model
    by Gleb18 » » in Bosch
    Last post by Maksim
  • Repair of PMM ARISTON LI41, when the circulation pump is turned on, it turns off. The pump works directly without problems.
    by tdcapital@mail.ru » » in Hotpoint-Ariston
    Last post by tdcapital@mail.ru
  • Replacing a heating element with a pump with a Bosh PMM
    by Alexx » » in Bosch
    Last post by Puppeteer
  • Bosch circulation pump
    by Romario 21 » » in Shopping Row
    Last post by Nippers
  • The circulation pump is leaking(?)
    by Sandroe » » in Electrolux
    Last post by Abyssinian Well
