NEFF S58M58X1RU/20. The indicator does not light up, the pump is runningOther manufacturers
Sergey_1971
My dishwasher: NEFF 58M58X1RU/20
Post by Sergey_1971 »
Hello!
Please help!
NEFF dishwasher. The light indication does not work; the pump turns on periodically. It is not possible to reset and reboot using the buttons. Unplugging for a day didn’t help. Without a scoreboard I can’t determine the error. A year ago this happened due to a leak, but then there was an indication and the error was identified. Now it’s different.
What could be the problem? Control block?
  • The pump is running, but the clean hose DOES NOT DRAIN!
    by Dmitriy » » in Bosch
    Last post by Dmitriy
  • Beko DSFS 1530 rinse aid end indicator does not light up
    by WaterSpirit » » in Beko
    Last post by WaterSpirit
  • Instead of an error code, when you press any key, the segments on the indicator light up
    by Andrewmusic » » in Bosch
    Last post by Andrewmusic
  • Connect without running water
    by Vladimir Sai » » in Burning
    Last post by Post
  • I want to buy a dishwasher for my dacha, there is no running water
    by stranger » » in General questions about dishwashers
