Good afternoon. I’ll say right away that I’m generally an oak. We watched a video on how to connect a dishwasher without running water and brought it to the dacha. I made a tank of water under pressure and turned it on. I filled half the tank and that was it. It beeps, drains, and does not start the cycle. I do not know what to do
Vladimir Say, I don’t have Gorenye, but Bosch, but at my dacha I pump water from a well with an ordinary submersible pump using an ordinary garden hose, which was connected to the dishwasher through adapters from Leroy Merlin, everything works.
[ref]Vladimir Say[/ref], I don’t have Gorenye, but Bosch, but at my dacha I pump water from a well with an ordinary submersible pump using an ordinary garden hose, which was connected to the dishwasher through adapters from Leroy Merlin, everything works.
Tell me please. I want to buy a dishwasher for my dacha, there is no running water. If I feed it from a 200 liter barrel 1.5 meters from the floor, will it work or not??? I can’t find the answer anywhere. In the store, managers shrug their shoulders. Give me some advice?!
Yes, I read it on the internet. Inlet pressure from 0.5 bar. What to use: a pressure booster pump or a pumping station?
the drain pump is new, the hose is clean, everything is purged, but when the water starts to drain, there is a bubbling noise inside the dishwasher from the propeller of the drain pump, but the water does not drain, as if there is no pressure or something else I can’t remember
Hello!
Please help!
NEFF dishwasher. The light indication does not work; the pump turns on periodically. It is not possible to reset and reboot using the buttons. Unplugging for a day didn’t help. Without a scoreboard I can’t determine the error. A year ago this happened due to a leak, but then there was an indication and the error was identified. Now it’s different.
What could be the problem?...
Is it possible to connect a PMM without an aquastop with a simple hose and how?
Can. Place the can into the body of the machine instead of a hose with an aquastop.
Then it will be possible to connect with a hose with union nuts, like for a washing machine.
