We cannot start the whirlpool adp 550 machineWhirlpool
Zarina
My dishwasher: Wirlpool adp550
Post by Zarina »
We recently bought a whirlpool adp550 machine. The simplest and cheapest model of all. We decided to launch it for the first time. Turn it on. It starts working, draws water, then starts beeping and switches to soaking mode, blinks, but nothing happens. This is where all the work stopped *x)
What to do? Please help, we are green in technology :sorry:
Igor_
Post by Igor_ »
I think the problem is a leak. The aqua-stop is triggered due to water leaking into the pan.
We need to drain the water from there and determine and correct the cause of the leak.
Evgeniy 198
 Re: Can't start whirlpool adp 550 machine
Post by Evgeniy 198 »
I had the same problem. With the same machine. I twisted the legs and set them level so that it stood stable and did not wobble. Everything worked. :)
Sergey 4444
Post by Sergey 4444 »
Did you manage to start your dishwasher, did you find the reason???
I have almost the same problem with this machine. When starting, the drain pump turns on, runs for 2 minutes and turns off and nothing happens anymore. The emergency valve checked everything is in order.
it’s simple - raise the drain into the sewer above the level of the machine
  • Whirlpool DWF 405 does not start washing
    by smokxx » » in Whirlpool
    Last post by Val
  • Whirlpool WIC 3C23 PEF dishwasher does not start
    by Nushka » » in Whirlpool
    Last post by Nushka
  • Whirlpool adp 450 wh
    by Max » » in Whirlpool
    Last post by Max
  • Holes in whirlpool dwh m00 w
    by lynxmike » » in Whirlpool
    Last post by lynxmike
  • Whirlpool ADGI 851 FD, Error E4
    by Alinka » » in Whirlpool
    Last post by Ola from Nekrasovka
