Smudges on dishes ⇐ Bosch
Abyssinian Well
Smudges on dishes
Pliz!!! I’m completely desperate... Bosch dishwasher series 2, white streaks remain on the dishes. I tried everything I could, changing products, salt, rinse aid. Salt settings at maximum. The instructions say if white streaks remain, reduce the amount of rinse aid, I tried... Nothing helps. Help, can anyone get rid of this problem????
Twinkle
- Наблюдатель
Re: Podteki on pots
#-incorrectly adjusted degree of water hardness, #-type and quality of regenerating salt, #-clogged filters, impellers, sewer water drainage system, #-quality and dosage of detergents, #-excess or lack of rinse aid, #-short washing cycles, # - the minimum temperature of the selected programs, # - the dishes are placed incorrectly, # - the ion exchanger lid is not tightly closed, # - the water supply pressure is reduced, # - the lid of the detergent compartment is jammed, # - the water hardness sensor does not work, # - the valve does not work supply of saline solution.
Slope
Re: Podteki on pots
We spent two months looking for the cause of the whitish smudges, but it later turned out that the salt in the tablets did not dissolve well and turned into stone
- 363 Views
Last post by alexander.doctor
- 12 Replies
- 32804 Views
Last post by Vika-Nika
