Error f 15 (pumps are spinning, heating element is checked) what else could it be?Hotpoint-Ariston
evafim
Post by evafim »
Hello. Can anyone help, tell me the reason for the error F 15 on the Hotpoint-Ariston PMM brand HSF 03 T 223. This is the situation. When the night washing program is turned on 1. The drain pump starts for 15 seconds 2. The circulation pump starts for 15 seconds (the water inlet valve does not open, the valve is checked by a tester and turned on to 220 V, there is no voltage supplied to the valve during operation) 3. Drain 10 sec. 4. Circulation 15 sec. And so there are five or six cycles with a decrease in the operating time of the drain pump. And error F 15 pops up. The drain turns on for 30 seconds and everything stops.
But the PPM started up a couple of times and worked until error F for 15 minutes 20.
Checked: heating element is normal, turbidity sensor is visually normal, the pumps are working and the error does not pop up during their operation - I think it’s normal , the mic on the aqua stop float is normal, the water supply valve is normal - what else can you check?
And can anyone tell me what the error description means "mismatch between sensor signals D and W"what are the sensors?
