Hello, the BOSCH dishwasher is noisyBosch
Igorsa
My dishwasher: BOSCH SWV 30D30RU
Post by Igorsa »
Hello, the BOSCH SWV 30D30RU dishwasher is noisy. He took it out and tilted it, water flowed out of it. It started working, what’s the reason?
Sergey_5555
My dishwasher: Bosh SMV 50E10 RU
 Re: Hello, BOSCH dishwasher is noisy
Post by Sergey_5555 »
There is a water leak, the aqua-stop has worked, i.e. the float floated to the bottom and pressed the button. The machine began to pump out water. The water was poured out, the float settled to the bottom again, everything returned to normal.
Igorsa
Post by Igorsa »
Thank you, Sergey. How can I fix it so that I don’t have to constantly take it out, tilt it and drain the water?
Sergey_5555
You need to look for a leak. First of all, tighten (carefully, since they are screwed into plastic) the bolts securing the drain pump cup, they are located inside the working area of ​​the sink, and pay attention to the clamp securing the circulation pump. To check/replace the latter, you need to turn the machine upside down with the tray and remove the tray itself. The pump pumps hot water under pressure, so this element may leak over the years.
  • Beko DSFS 1530 dishwasher is noisy
    by DmitroNik » » in Beko
    Last post by DmitroNik
  • Dishwasher BOSCH
    by Svetlana Bogatyreva » » in Bosch
    Last post by Svetlana Bogatyreva
  • Dishwasher BOSCH
    by Evgeny » » in Bosch
    Last post by Evgeny
  • Dishwasher bosch
    by Stepan » » in Bosch
  • Dishwasher bosch
