Doesn't wash dishes ⇐ Discount
Автор темыOLpecudo
Doesn't wash dishes
Good afternoon, forum members. This is the problem: the PMM turns on, draws water, but does not wash; after the time allotted by the program has passed, it completes the cycle, leaving the dishes in the same condition. Please help
Artem
Re: Doesn't wash dishes
1. Pollution / most often the holes in the impellers become clogged with food debris, grease and limescale / clean / 2. Increasing the size of the holes / sometimes the holes are corroded by household chemicals. Due to the increase in the size of the holes, the jet pressure becomes weaker, and the impeller rotates poorly or does not rotate at all /replacing impellers/ 3. Wear of the gasket/ over time, the sealing gasket at the junction of the water supply channel and the impeller itself loses its tightness. As a result, water partially or completely does not enter the rocker arm, but flows bypassing the sprinkler. The rotation of the sprayer is poor or absent, and the dishes remain dirty / the gasket needs to be replaced with a new one / 4. The water supply channel is clogged, the circulation pump is faulty, the actuator / water flow distributor is faulty /, the control unit is faulty, the wiring or contacts in the circulation pump circuit are damaged /service operation/
- 655 Views
Last post by radmir
