Inconsistency between instructions and realityBeko
FVL
Post by FVL »
Hello.
Dishwasher DFS25W11. I can’t adjust the water hardness level (it should be minimal), because... If, according to the instructions, you press the start delay and P+/P, and then P+/P, then what appears on the display is completely different from what is in the instructions. When you successively press the start delay button, instead of r1-5 the following appears: 1 - HFt, 2 - 1Ft, 3 - 5Ft. 4 - EEP. 5 - dno.
Please help.
 Re: Inconsistency between instructions and reality
Turn it on. Then simultaneously press p+ and delay start
But
Post by But »
Please tell me that the error code 1:Ft appears periodically and the machine does not start the program. After turning the power off/on several times it starts working again.
  • Inconsistency between instructions and reality
    by FVL » » in Beko
    Last post by FVL
  • Inconsistency between washing times in the instructions and in reality
    by Alexander Alexandrovich » » in Beko
    Last post by Alexander Alexandrovich
  • No instructions.
    by Vital » » in Electrolux
  • Instructions for dishwasher XW-U1-220 Convito
    by Sergey » » in Other manufacturers
    Last post by Evgenia.telya
  • instructions for exp.gorenje gvi 7640
    by edikvbg47 » » in Burning
    Last post by edikvbg47
