Pmm ElectroluxElectrolux
Allinkov
 Pmm Electrolux
Post by Allinkov »
Hello. There is a problem with the PMM: when you turn on the program, it constantly drains water. The “master” has arrived. Everything was inspected and everything was in order. It was decided that the problem was due to low water pressure. Time passed, the pressure increased, the problem remained. I called the “master” again, this time a different one. He said that there was a problem with the board and needed to be replaced. Changed it. I worked for four days. Everything is the same, I started draining the water.
What should I do with it to make this miracle work? *x)
  • PMM Electrolux
    by Pavel » » in Electrolux
    Last post by Crater
  • Electrolux ESI47500XR
    by Marina gives » » in Electrolux
  • Template for pmm electrolux 45 cm
    by Video controller » » in Electrolux
    Last post by Video controller
  • Electrolux ETM 43211L
    by Dmitry1111 » » in Electrolux
    Last post by Dmitry1111
  • PMM Electrolux ESF 45010
    by Smart » » in Electrolux
