Electrolux esf 43020 the aqua stop is triggered.
I removed the side cover, started the washer, during observation I discovered that water began to drip from two hoses into the pan and then the aqua stop triggered.
I assume that water entered the chamber in a larger volume what is necessary and how to pour water through two hoses.
QUESTION: Which part is faulty???
Presostat (water level sensor)
or
Water supply solenoid valve
Electrolux esf 43020 aquastop is triggered ⇐ Electrolux
Flash
- My dishwasher: Electrolux
Re: Electrolux esf 43020 aquastop triggers
[ref]Ilya 1111[/ref], good afternoon!
Did you solve the problem? The same thing happens...
- 22018 Views
Last post by Flash
- 787 Views
Last post by pasha
Tell me, is it possible to connect the PMM without aquastop and how?
by Roman 20101977 » » in General questions about dishwashers - 2 Replies
- 8478 Views
Last post by Vincentov
by Roman 20101977 » » in General questions about dishwashers - 1 Replies
- 7464 Views
Last post by Operator
