Good afternoon everyone
Help what the problem could be, I broke my whole head
Story:
A hamster escaped, settled in the dishwasher, lived there for two days while I I didn’t get it from there. Then, when the machine was turned on, it began to show an error (the brush light was blinking) water supply error. Naturally, I immediately realized that the hamster had done a lot of business there.
I called a technician, they removed the pan, it turned out that the hamster had chewed through the blue wire to the water supply sensor and the wire that goes to the float mic (aquastop)
In general The master spliced all the wires together and sealed them.
Assembled, the machine started washing, went through a full cycle at 65 degrees. During the next wash, after starting up and filling up with water, the machine started to go into error again, only now the light started blinking not on the brush, but on the faucet. I found out on the Internet that this error appears when a leak occurs somewhere. I disassembled the machine myself, removed the pan, everything is dry everywhere, the foam (float) is dry, there is not a drop or a hint of a leak anywhere. I suddenly thought that the foam plastic somehow shorted the microphone of the aquastop and that’s why it worked, I removed the foam plastic to make sure it didn’t touch the button, put everything back together in the reverse order, and still the machine goes into error at the beginning. I called the technician, he threw up his hands, said to try to adjust the water supply with the tap, make the pressure more/less, it didn’t help
Why does the machine go into aquastop if I removed the foam and the microphone does not close in any way, what else could it be? I did a reset, it didn’t help
Until this day, it was so that the car started up 2 times and did not go into error, went through a full washing cycle and at the very end only went into error with a flashing tap. Give me some advice, thanks to those who mastered this long text) It’s a pity to throw away the machine, Bosch, Made in Germany) it works, heats water, draws and drains, which means all the pumps are working, but what a small Reptile (hamster) the error with the flashing tap does not work she works fine...
Sent after 2 hours 12 minutes 42 seconds:
Comrades! I just solved the problem! It turned out that the water supply tap under the sink was broken and did not regulate the water pressure in any way, I tried to turn off the cold water directly in the riser, turned it off halfway so that the sink could barely flow and lo and behold, the error stopped appearing, the machine washed smoothly! Apparently there is a very strong pressure there, I used to remove the supply hose from the machine and substitute a bucket, a five-liter bucket was filled in 15 seconds such a pressure there .. so anyone who has a similar problem can try to solve it this way
Aquastop is triggered ⇐ Bosch
- 22431 Views
Last post by Flash
- 22016 Views
Last post by Flash
Tell me, is it possible to connect the PMM without aquastop and how?
by Roman 20101977 » » in General questions about dishwashers - 1 Replies
- 7460 Views
Last post by Operator
by Roman 20101977 » » in General questions about dishwashers - 2 Replies
- 8475 Views
Last post by Vincentov
