PPM does not startBosch
Alexei
 PPM does not start
Post by Alexei »
After interrupting the operation of the Bosch PPM (opening the door), the engine does not start! what could it be???
Albert
 Re: PPM won't start
Post by Albert »
Alexey: the engine won’t start!
In general? Even after a long period of time?
Which light bulbs are lit at the same time? What do you have to do to make the machine work normally?
 Re: PPM won't start
current flows to the motor! because it hums and gets hot! The indicator lights up as if everything is fine! but there was something that skipped to rinse! If you wait another minute it starts! Suspicion of Conder, but why then from the beginning of the program everything goes fine until you open the door!??
 Re: PPM won't start
Maybe some sensor is acting up when hot?
  • Doesn't start
    by Qwerty » » in Midea
    Last post by Qwerty
  • Dishwasher won't start
    by _long_ » » in Electrolux
    Last post by _long_
  • Pmm Bosch won't start
    by Mikhail 80 » » in Bosch
    Last post by Mikhail 80
  • Dishwashing does not start
    by Constantine » » in Electrolux
    Last post by Psy40263
  • SPV40E30RU no cycle start
    by Vegas » » in Bosch
    Last post by Vegas
