Dishwashing does not startElectrolux
Constantine
Post by Constantine »
Good evening, I have an Electrolux ESF9526LOW 911519227, the machine is 1.5 years old.
One fine evening I loaded it, selected the program, pressed start, the washing process indicator came on, but there was silence! The pump did not drain water does not draw water is simply silent, invited a specialist, couldn’t do anything, and so on 7 times. They checked everything, the board was changed by the officials, but there was no result!
The price of the board is 22000t.
Please help me, is this really fee ?
Maybe someone had this,
Psy40263
 Re: Dishwashing won't start
Post by Psy40263 »
The problem is definitely most likely in the board, there are two identical machines, one has the same problem, but if you put a known good board on it, then the machine works without any problems. So far I haven’t found the reason either, I blame the firmware, but if yours was sewn and there is no result, then you need to try to look for the problem in the module itself
  • The quality of dishwashing is declining
    by Elenka » » in Siemens
    Last post by Elenka
  • How to choose dishwashing equipment?
  • Repair of PMM Bosh SRV55TO3EU/37, poor quality of dishwashing.
    by Reed » » in Bosch
    Last post by Reed
  • Candy cdi45 dishwashing program selection sensor does not light up
    by Ido221-24 » » in Other manufacturers
  • PPM does not start
    by Alexei » » in Bosch
