It was better with the pillDishwasher chemicals
Dishwashing detergents: tablets, powders, salts, flavors
Svetlana
Post by Svetlana »
Hello. Here’s the problem: I’ve always used Somat tablets before. I won’t say that the soap is perfect, but it’s still good. I decided to switch to powder. I bought the finish. And now a white coating has appeared on the dishes. What could it be?
ADP
 Re: It was better with the pill
Post by ADP »
The powder washes just as well as the tablet, only together with salt and rinse aid, and it is also MANDATORY to adjust their dosage depending on the quality of your water. I almost always wash with powder, everything is set up correctly - there is no difference with tablets, now I use Somato powder, it washes aluminum and does not spoil it, as it turned out)
  • Bosch SMV40D00RU/34 throws the pill away
    by Kahhhhx » » in Bosch
    Last post by Einstein
