PMM Beko 5833 takes up a lot of waterBeko
Serge
Post by Serge »
​The PMM began to take in more water than needed, and not immediately.​ As a result, the excess water is drained into the pan, the leakage sensor is triggered and the water drain is turned on. As far as I understand, there is no water level sensor in this model? Is the flow regulated by a flow sensor? Is it not working correctly? Is there any way to check it? Or is that not the problem?
  • . PMM VVK takes on water and stops
    by Hanych » » in Other manufacturers
    Last post by Hanych
  • Beko does not drain water
    by Lord Curzon » » in Beko
    Last post by Lord Curzon
  • Beko DIN1531 stops after filling with water
    by Sergey.antonyuk » » in Beko
    Last post by Alexey Arkhipov
  • Beko DFN 6837 does not heat water, but the heating element works
    by seaman2 » » in Beko
    Last post by seaman2
  • Beko DIS26012
    by DeN102Russia » » in Beko
