Kerting dishwasher fills with water but does not washDiscount
Sergey164
Post by Sergey164 »
Good afternoon. The Kerting dishwasher draws water, and that’s where its work ends. I open the dishwasher and there is water in the tray. If you turn it on and off, the water is drained and again collected in the pan. Tell me what could be. Filter is clean
 Re: Kerting dishwasher fills with water but does not wash
Man, what kind of breakdown did you end up having? I have the same problem.
Ivan
Post by Ivan »
I have the same thing, what was the problem?
Sergey164, you can’t be such an asshole! Same problem and no solution.
Anna
Post by Anna »
So what was the problem!!! *x)
I had this problem with my Miele dishwasher. The reason is that the main pump supplying water to the blades is not working. Moreover, the pump itself turned out to be working; it simply jammed due to prolonged non-use. I poured some WD-40 in, waited a little, and the pump shaft began to spin easily. In the future, the problem recurred, if you did not use the dishwasher for 3 weeks, it was also corrected.
I’m also interested in what happened? I have the same.
Most likely something with the recirculation pump
Post by Fulcrum »
Guest: 06 Apr 2021, 13:29 I’m also interested in what happened? I have the same thing.
looks like the recirculation pump is clogged or just stuck
I blew into the pipe that goes to the turntable and it started working. Thanks for your help in finding the problem. My wife was already panicking
Valery
Post by Valery »
Good afternoon everyone!
I read this forum, but I still don’t understand how to deal with this problem. I have a korting kdf2095n dishwasher
It fills with water, the relay trips and the machine stops working. We haven’t used it for a year now. Can anyone clearly explain how you dealt with the problem? Unfortunately, I didn’t find any video on the Internet to solve this problem.
I would be grateful for your help.
Sent after 35 minutes 21 seconds:
Guest: 08 Jun 2021, 05:11 I blew into the pipe that goes to the turntable and it started working. Thanks for your help in finding the problem. My wife was already panicking
Which pipe and how did you get to it?
Sent after 4 minutes 13 seconds:
Anna: 15 Jan 2020, 18:27 So what was the breakdown!!! *x)
Have you figured out the problem?
Sent after 38 minutes 19 seconds:
Sergey164: 17 Apr 2018, 22:26 Good afternoon. The Kerting dishwasher draws water, and that’s where its work ends. I open the dishwasher and there is water in the tray. If you turn it on and off, the water is drained and again collected in the pan. Tell me what could be. The filter is clean
Have you fixed it? What was the question?
Vladislav
Post by Vladislav »
Found the answer
Yandex: video/touch/preview/15861624199409626013h
Abyssinian Well
Post by Abyssinian Well »
https://Yandex.ru/video/touch/preview/15861624199409626013h
Just change Yandex to Yandex
Izilanov Vladislav
Post by Izilanov Vladislav »
I solved the problem:
If you turn the engine shaft with a screwdriver, it starts.
I disassembled the engine, turned it, listened, the rubber bands on the shaft creaked. I lubricated everything with WD-40 type grease, the shaft bearings and everything with the impeller, twisted it with my hands in the grease until the creaking disappeared.
I put it back together - everything worked!!! :)
  • Please help me determine what could have happened to the dishwasher. After turning it on, it fills with water and then stops.
    by Arshahhh » » in Candy
  • Dishwasher Kerting 60165 E1
    by Yerina1 » » in Discount
    Last post by Slope
  • Fills with water and drains after a while
    by Krekc » » in Bosch
    Last post by Krekc
  • Constantly fills with water.
    by Alexander34 » » in Electrolux
    Last post by Alexander34
  • It fills with water, then it hums and that’s it!
    by Anton36 » » in Hansa
    Last post by Puppeteer
