Washing modes are not carried out ⇐ Bosch
Автор темыAlexander
Good evening Bosh dishwasher is 7 years old, the most common one without automatic mode. I turned on the button, turned the knob to mode 1 and it kept washing for 1.5 hours. Today, when you turn it on, you only have to periodically scroll through the modes manually, otherwise you may stand and thresh in the washing, rinsing, or other mode until you help it move further. What could it be? Periodically, the mode knob moves on its own as it should, then again gets stuck in some mode.
123
Re: Washing modes not working
Alternatively, the float gets stuck. Open the side cover, find the float, remove deposits and dirt that may prevent the float from rising/lowering depending on the water level.
- 23167 Views
Last post by mahanka
- 4904 Views
Help me overcome the ELECTROLUX ESL94200LO dishwasher. Modes do not switch.
by Andrey ELECTROLUX » » in Electrolux - 2 Replies
- 24757 Views
- 7 Replies
- 8287 Views
Last post by schealex
