Bosch does not wash after being idle for 3 monthsBosch
Svetlana
Post by Svetlana »
My Bosch dishwasher, after a long period of inactivity, fills and drains water, but does not wash. This has already happened. This causes the gasket to stick. On the advice of the master, I filled it with water before leaving. But now I’ve been trying to start the machine for 3 days, but it doesn’t work. There is a flood of water, then silence.... at the end of the program, the water is drained. Tell me what to do? Thank you.
mario
Наблюдатель
Наблюдатель
 Re: Bosch doesn't wash after being idle for 3 months
Post by mario »
Which gasket do you think is sticking there? :ROFL:
It is possible for the valve (one of them) to stick if left idle for a long time. Remove the side cover and tap them lightly, or better yet, remove the valves and move them manually.
  • Bosch SVM40E10 after the start goes to the end of the wash.
    by Sciper » » in Bosch
  • Stagnation of water after a Bosch wash cycle
    by salamon4ik84 » » in Bosch
    Last post by CorePureEmerald
  • BOSCH SRV55T03EU/38 - wash program time is too low
    by Sergey (Khimki) » » in Bosch
  • How to turn off the sound signal at the end of the wash? bosch smv30d20
    by Ilya » » in Bosch
  • Doesn't wash away
    by Too bad » » in Electrolux
