BOSCH SPV 40E10RU is leakingBosch
Anton
Post by Anton »
Hello. We bought BOSCH SPV 40E10RU. At first start after min. 20 water began to flow in droplets from below in front. What could be the problem?
 Re: BOSCH SPV 40E10RU leaks
Check the rubber seal, maybe it just came out of the grooves? And what product did you use? Specifically for dishwashers? Because if you pour in regular dishwashing detergent, there will be a lot, a lot of foam, and it will start to crawl out of all the cracks.
I already looked at the seal and it didn’t come out. The product I used for dishwashers was Finish powder and rinse aid.
  • Bosch SPV 40E10RU error at the end of drying
    by start_lost » » in Bosch
    Last post by start_lost
  • Bosch dishwasher Rinse aid dispenser is leaking
    by right1 » » in Bosch
    Last post by right1
  • Wellton WDW T5 is leaking
    by not » » in Other manufacturers
    Last post by not
  • ESL65070R is leaking
    by GuitarFan » » in Electrolux
  • The dishwasher is leaking, can anyone tell me?
    by Lyokha » » in Bosch
    Last post by ivan. orlov
