Water sprayers don't workSiemens
ntcl21980
Post by ntcl21980 »
Good afternoon. Narrow built-in dishwasher from Siemens. I started washing dishes badly. The technician who came reported that the water sprayers were not spinning, but were spinning. The water itself is supplied. But either these fan strips are clogged, or the “snail” is out of order. Added two packets of cleaning powder. Did not help. They say that this pressure compressor along with the built-in heater is expensive. What do you advise? Should I buy a new one or repair it? If you are repairing it, how do you remove the built-in machine from the furniture? Thank you in advance.
 Re: Water sprayers don't work
The easiest option is to try cleaning the water sprayers https://youtu.be/mk6SoKcVp4g? t=3m43s
Yuri
Интересующийся
Интересующийся
Post by Yuri »
The actuator is blocked by foreign objects. Do you hear a crackling sound when working?
The rocker arms are clogged. Is there a clog sticking out of the nozzles?
The circulation pump very rarely fails.
  • Failure in work
    by Alexei » » in Indesit
    Last post by Alexei
  • Failure in work
    by irina.smolensk2010@mail.ru » » in Bosch
    Last post by irina.smolensk2010@mail.ru
  • Failure in work
  • Programs don't work
    by Daria » » in Midea
    Last post by Daria
  • The backlight does not work.
    by Roman Medvedev » » in Flavia
    Last post by Air Shower
