The backlight does not work.Flavia
Roman Medvedev
Post by Roman Medvedev »
I noticed that the lamp inside the dishwasher was not working. Is it somehow turned off (turned on from the buttons)?
If not. How to change it, I didn’t understand how to get it from there. *x)
Roman Medvedev
 Re: Backlight does not work.
Bi60 cascading light s
Alexey.isaenko
Post by Alexey.isaenko »
well, to hell with it
Post by Fulcrum »
Roman Medvedev: 11 Feb 2023, 19:35 I noticed that the lamp inside the dishwasher does not work. Is it somehow turned off (turned on from the buttons)?
There is an LED module, most likely it is turned on by the microphone in the door lock, either it is a problem with it, or with the lamp itself, the lamp is in the housing from above, you need to pick it up from outside the car body
Air Shower
Post by Air Shower »
Is it possible without backlighting? Will the machine work?
  • Failure in work
    by irina.smolensk2010@mail.ru » » in Bosch
    Last post by irina.smolensk2010@mail.ru
  • Work without top cover.
    by language » » in Bosch
  • Programs don't work
    by Daria » » in Midea
    Last post by Daria
  • Failure in work
  • Failure in work
    by Alexei » » in Indesit
    Last post by Alexei
