Kaiser S6081XL, gives error 1 (increased fill time)Kaiser
aposol
My dishwasher: Kaiser S 6081 XL
Post by aposol »
Good afternoon.
A problem has arisen: error 1 appears on the screen.
Background: the intensive washing mode was started, 10 minutes before the end an error appeared and the cycle stopped.
Now I’m trying the rinse mode, the drain pump works (I manually filled in water, checked), and then silence and error 1.
As far as I understand, you need to check the hose with the aqua-stop and inlet valve.
The following questions arose:
1. Is it possible to visually understand that the problem is in the hose (remove it, look with your hands)? There were cases of "dirty" water supply in the system, so the incoming mesh was quite dirty. I cleaned it, but it didn’t help. Maybe the inside of the aqua-stop block is also clogged, but how to disassemble it?
And if in it, then what hose can be replaced at least temporarily?
2. Did I understand correctly that by first disconnecting the intake valve, you can check its resistance with a tester?
I just want to get into it before analyzing the PMM, otherwise you never know... *x)
  • Sometimes but not every time when washing, error 20
    by Andrey air » » in Electrolux
  • Fill the hose with aquastop
    by Kharitonov_al » » in Midea
    Last post by Kharitonov_al
  • PMM Electrolux does not fill with water.
    by Maksim » » in Electrolux
  • Electrolux ESL94300LA does not fill with water
    by Jan007 » » in Electrolux
  • The Kandy trio doesn't fill the water.
    by rhodion » » in Candy
    Last post by Sergey
